I am doing basic maintenance on a diesel in my Challenger (Westerbeke/ Perkins 4-107) for first time. OK, basic oil changes: there must be a better way. I bought a PAR hand pump to try pumpping oil out the dipstick hole. A thousand strokes later I had a quart of oil and was sucking air. I removed the heat exchanger (since I was replacing it) and accessed the drain plug under the engine, and got another three quarts overflowing my pan,dumping into the difficult sump space below the motor. Four hours total and a total change of clothes after cleaning bilge later, I had my first oil change done (heat exchanger still not reinstalled). There must be a better way.
