oil canning at the motor mount
Mike Whalen
My Evinrude 9.9 is mounted on the starboard on my '76 O'day 25. There is a piece of what looks like 1/2 inch plywood in the lazaret through which the mount is bolted. Recently noticed the oil canning. I lifted up on the mount, to relieve pressure, but no change. Is this something I should be concerned about? If so how do I fix it? Thanks in advance, Mike
Josh
Go bigger...
IF there is nothing wrong with the fiberglass other then it's being pulled on, you need to back it with either thicker and longer/wider plywood, or remove that and replace it with two by fours. When I purchased my 22, the engine mount was only backed by fender washers! Needless to say, this wasn't acceptable. I removed the fiberglass wedge that was on the back and was stock as this was also causing problems. I modified the engine mount so that it would mount at the transom angle and still drop the engine in perpendicular to the waterline. I took a large peice of machined aluminum that was used by the previous owner as part of the engine mount and used this to back four of the six engine mount bolts. I then used a piece of two by four to back the other two. I can now hang off the back of the engine mount without worry, and I wiegh twice as much as the engine, so I think it's good. You are better off over building it like I did, then you won't have to worry about it happening again! Josh
R.W.Landau
Just fixed the same problem.
I removed my motor mount to paint the boat. The previous owners did not seal the mount well. On the starboard transom the transom is about 1/4" fiberglass with 3/8 to 1/2" plywood core and a fiberglass layer on the inside of the boat that is maybe 1/8" think. My plywood core core was gone, rotted and gone. I injected about 1 gallon of polyester resin into the core space. the transom is now firm and I am installing an 8"x8"x 1/2" aluminum plate on the exterior between the mount and the transom to spread loads. I am installing a plate 12"x12"x 1/2" on the inside. hope this helps r.w.landau
