Bill Ebling
To date our 1985 H31 sails exclusively within in the Chesapeake Bay. Thus 100% of the time we empty our holding tank via the numerous and readily available pump out stations. Two years ago we simplified our sanitation system so our toilet now only pumps to the holding tank and the holding tank can only be emptied through the deck discharge port. The thru-hull for direct discharge has been capped, no Y-valves or pumps...new SeaLand hose...No odor...The proper solution for our cruising ground.This summer we are considering a few 24 to 48 h offshore trips possibly up to RI or around Delmarva from the Delaware to Virginia capes. This has prompted me to consider adding a portable, high capacity emergency manual bilge pump with hoses in the lazerette. (Will do for safety sake even if we stay in the bay)With the increased crew members required for off-shore sailing I am worried about the low capacity of my sanitation system until we make land-fall. Offshore sailing will be a very rare endeavor, thus I would like to retain the simpler features of current sanitation system.Question: In a pinch, and with the proper deck fitting, could the new manual bilge pump also be used to dump the holding tank overboard through the deck access point while we are out beyond the offshore limit? Of course I will have plenty of seawater available to flush out the emregency bilge pump and its hoses after the pump-out. Any suggestions on the pump, hoses and fittings or alerts to the pitfalls of this approach would be appreciated. Bill EblingYesterday's DreamCrab Alley Bay, Kent Island MD1985 H31 hull# 31395
