O'Day Rudder Crack
A
Adam
I was painting the hull this weekend and noticed a crack down the forward centerline of the rudder. It was approx 18" in height and quite thin. I spread it open a bit with screwdrivers and injected fiberglass resin inside then glassed over the outside after removing the paint. Any better ideas or solutions?
Brian
Repair
What you have done should work fine. If the crack is open the you should use a filler like West System 404 to thicken it before filling. If there is a possibility of there being any moisture inside, then I would have ground open the crack and allowed it to thoroughly dry then repaired the fiberglass using standard methods. Of course that takes a long time (months of drying time if the boat is stored on the water) to repair using that method. Good luck
james rohr
sounds correct!
I'm assuming that you overlaid a layer of glass reinforcement over the crack.this is a common problem to almost all rudders. also the trailing edges tend to split also.
A
Adam
Thank You
Thank you, Brian and James. It seems to be holding together quite well so far. I also injected about 1/2 quart of epoxy into the lower 1/2 of the rudder because of some delamination. Everything seems to be pretty solid once again.
