I have acquired a very older Spirit model--10'2" sail number 104. How do you decipher the build date on this model? Best I can figure they started building them in 1959. The original wood mast is still in use, and excellent condition.
I have an O'Day format sheet that explains what the hull number digits stand for in most of their models but unfortunately the O'Day Sprite is not listed. I assume that you are referring to the "Sprite" because O'Day built a 10' 2" model by that name. Usually, the last two numbers in the hull number signify the date in which the boat was built. The beginning of the numbers is preceded with the letters, "XDY" which stands for the manufacturer, O'Day. The next letter stands for the model and the four numbers after that are the serial numbers.I have acquired a very older Spirit model--10'2" sail number 104. How do you decipher the build date on this model? Best I can figure they started building them in 1959. The original wood mast is still in use, and excellent condition.
Evidently the O'Day company didn't include the Sprite in their format. Check out this site for more info: http://www.iheartodays.com/index.htmlThe plate is missing, but the previous owner made a photocopy of it; reads as follows:
Made by Marscot Plastics inc.
Fall River, Mass
for
G.D. O'DAY ASSOCIATES, INC.
Boston, Mass
HULL NO 3438 CLASS NO S-35(?) can't make out the last digit or letter
During repair to the stern area the plate was removed and then misplaced.
