Thanks, that's the direction I was headed. The centerboard on the 28 isn't especially heavy, so most modern cordage (like the term) would be ok. Two blocks, and there's a separate line with purchase that gets cleated. Polyester cover still a good idea for abrasion resistance.I hate to see your post fall down the list so here's an opinion.
I call Amsteel and other similar cordage modern cordage. I can't keep current on the different fibers let alone the brand names.
I think some version would be very good for your pennant. There are a few properties you should shop for: One is strength. The good news is most or all are strong enough that you could downsize. Second is abrasion resistance. The pennant will probably go around one or more blocks and may even rub on the hull. You could look for something with a polyester cover too. Three it shouldn't so slippery that it can't be held in a stopper or cleat. Four it should be low stretch and low creep. Five is that it should be easy to splice to make a nice clean attachment to the centerboard.
Know the weight of your board and visit sites for New England Ropes, Sampson, Yale or chandlers like Fisheries Supply for specifics cordage properties.
5/32" 7 x 19 stainlessI looked on the Yale site. It was not so easy to use. Fisheries was useless.
I assume the existing wire rope is 7x19 stainless. What is the diameter of the wire?
Went to Rudy as my first resource, he didnt have anything.The one I got from D&R for my O'Day 25 was not wire. I had a lot of jamming and chafing issues with a previous boat's pennant so I went straight to the source to avoid complications
Thanks, that's what I thought I'd do. Rudy did say, and I've heard other places as well, that the setup on the 30 is similar to mine. There weren't a lot of 28's with a centerboard.Stawn......I have a 1983 O'Day 30 and have replaced the centerboard pennant twice. Once in the water when the lower loop opened up as a result of corrosion of the nicopress type material holding the loop together at the centerboat and once on land 32 years later as preventative maintenance. I purchased a new one from D&R 30+ years ago and never used it as my boat is in saltwater and I was concerned about the loop opening up again in the salt water. My last change of the pennant was in 2021 and I used New England Rope 3/8" diameter 6.6% stretch, 4,800 lb nylon braded line, West Marine part # 121475 with spliced loops at the upper and lower ends. To attach the line to the centerboard I used a Harkin Shallow Bow Shackle, Harken part # 2132, West Marine part # 5253612. The only differnce I noticed using the braded nylon is that there is a little spring in the line when lifting the centerboard that was not there in using the braded nylon & stainless steel line. Attached are some pictures.
It was seven or eight years ago but I believe the one on my 25 was somewhat long with light guage metal. The line was your typical braided line like Sta-set. My centerboard weighed around 50-60lbs. Its a pretty light load on the line.Went to Rudy as my first resource, he didnt have anything.
Do you happen to recall what the shackle looks like, size/shape/etc. I've read a while back that it was fairly small to avoid jamming.
