I helped a friend of mine deliver his 1986 272 from Cape Cod to Bristol RI., a year ago. This boat wasn't the Limited Edition. It had tiller steering and an outboard. I found that in this particular boat, it was very uncomfortable to sleep in the Port aft settee because the aft portion of the boat set a little higher. I had to turn around and sleep with my head facing the stern. I think that the reason for this has to do with the minus 500 LBS of having no inboard engine and wheel steering pedestal steering, but I may be wrong. Outside of that, the boat sailed quite well with it's wing keel and was able to get into shallow areas, which would really appeal to me for the sailing that I do. The inside of that boat was beautiful. I noticed that all the halyards and control lines came over the cabin and into the cockpit, which isn't something that I'm used to, but it's a good feature I suppose. The 272 LE is the better boat. There's no question about it. Ordinarily, I would sleep up forward in the V birth, but he had a lot of stuff in there, and there wasn't much room at the time. One of our YC members has a 1986 O'Day 26 with an outboard on the transom and tiller steering, and I noticed that his boat sits a little higher in the stern when it's at the mooring. So, I think that the weight may have a little something to do with it. Normally, if you're laying down in a quarter birth, you want to have your feet pointing toward the stern and the rest of your body should be higher than your feet. Otherwise, it isn't too good for someone like myself who has Acid Reflux Disease. I really don't think that this will be an issue with the 272 LE. Outside of that, I thought that it was a great boat.
Joe
