As noted in a earlier Thread, Crest aluminum has sections of toe rail and rub rail for the O'day 39 and 40. I just received it so now the question is : How to I replace and seal it. The toe rail is thru-bolted through the hull deck joint and then completely glassed in on the inside.
I intend to drill out each bolt since I assume the bolts will not budge after being glassed in. I'm thinking I may try to bed the toe rail with Butyl caulk and use self sealing bolts and forgo the the fiber glass on the inside unless of coarse it leaks. I then can seal it with fiberglass.
The Stanchion sockets breakup the toe rail so I will be replacing three 8 foot sections. The two forward sections near the bow have very little bow in them. One section midships has considerable bow. It will take some force to get it into place. I'd like to use butyl tape but It might interfere with bowing the rail
Anyway... I'm look for opinions and suggestions. thanks in advance for your help.
