Good Day,
I just purchased an 87 O'Day 35 in excellent overall shape but of course, it needs a few things. If I may, I'd like to ask a few questions (I searched the archives but couldn't find answers to these):
* Someone put on a 44" wheel, while great for steering leverage it makes getting around the cockpit difficult. What size was the original wheel? Do you like the original size?
* There are a few gelcoat chips to touch-up (the gelcoat is in amazing shape, very impressive) - does anyone have a source for gelcoat that matches O'Days from that era?
* I desperately need to bring the main halyard back to the cockpit as raising the main at the mast is not for the faint hearted unless in flat water - I will also be leading the reefing and out-haul lines aft but the halyard is my first priority. I read Ed Ryan's article in the modifications section - it's pretty straightforward. My question is: for anyone that has done this or has a boat with it already done, how are the rope clutches attached to the deck? The removable panel in the headliner allows access to the underside of the deck for the deck organizers but where the rope clutches go, there's no access. The cabin-top winch has bolts that protrude through the hull liner but if I do this for the rope clutches, the bolts will be above the galley floor and will be a real threat to people's heads (I have just enough headroom as it is).
Thanks.
Thanks.
