Jim
I have an O'day 31 with a Universal M18 engine that I've owned for several years. This year, I replaced the Raritan water heater with a Force 10 water heater, both water heaters have a heat exchanger that uses the engine as well as shore power to heat the water. I finished the work and tested it last week at the dock with no problems, but took it out on the water yesterday and after about 5-10 minutes under power at about 2000 rpms, the engine overheated. When I got back to the dock, I thought I may have hooked up the heat exchanger in reverse (not so, it was correct) and disconnected the return line and no antifreeze came out, leading me to conclude that the coolant is not being pumped through the engine, resulting in the overheating. I tried the air release valve on the engine (with engine on/cool; engine on/warm and engine off/warm) and got no air releasing. Does this sound like the coolant circulating pump?Any help would be greatly appreciated. Also, if anybody knows of a competent marine diesel mechanic in the Quincy, MA area, I would very much appreciate a name/number.Thanks!Jim Malloy"LegaSea"Quincy, MA
