PICK AN O'DAY 28
Although I am not familiar with the O'Day 280, I suspect it was a late model production boat similar to the O'Day 272 which does not compare favorably with the earlier O'Day 27. Just prior to shutting down production, Lear Siegler began manufacturing O'Day sailboats (like the O'Day 272), where they cut corners (i.e., carpeted overheards, etc.). If that is the case with the 280, and you want a good heavy well constructed hull, I would definitely recommend the O'Day 28. If you check the classifieds for prices you will most likely find late model O'Day 28's (i.e., 1983-86) priced considerable higher than the O'Day 280. If anyone out there knows differently, I would also like to know!Regards, Bruce C.
