Ahoy,
I'm a bit rusty at this. I'm here to help an old friend with his 28 Oday. 1982, I believe. He's been concerned about a wobble in his steering column. Lew doesn't get around too well, and has a hard time seeing the underside of the system, but thought it was due to the rotting of a wooden backing board supporting the cockpit sole. I took a look (and a few photos). First, I suspect this is the original system. I do see deterioration of what I assume to be marine ply around the backing plate, but it appears that the plate itself was designed to bolt flush to the sole. There appears to be a cut-out for its placement. Am I right?
I'd be happy to send a picture to any knowledgeable owner (I assume photos can't be sent this route). I'm hoping that his problem isn't that bad, that maybe new bolts tightened up would be adequate. If in fact there used to be one large, solid backing board, that will be one huge headache to replace.
Lew's never going to take a following wave over the stern, forcing him against the wheel. On the other hand, if the system should be reinforced, I'll let him know.
Thanks, all.
Paul Koestner
S/V Laura Lynn (Morgan 34)
Thanks, all.
Paul Koestner
