Jason Lemos
Help! Have a oday 28 with a small crack in the center of the area between the primary and secondary sidestays on the port side. This area was neglected to a point that the area is now so soft that mast stability is questionable. The mast has been removed for safety. My question is what is the best way to repair this area back to the rock solid state it should be? The forward most sidestay does not bolt through as the rearward one does. It looks to have just a metal backing plate in between the balsa core. At this point I cannot see how it is attached. Should I swiss cheese the area and refill with epoxy/hardener or is a skin removal a better option? Anyone have this happen to their boat and if so what did you do? Thanks.
