O’Day 28 backstay
Dec 25, 2014
4
Oday 28 St michaels
Anybody know the length of the O’Day 28 backstay from mast to where it splits? I’d like to pre-make/ install that part of the backstay with an insulator at the top without having to climb the mast twice. Can’t find that info on any spec sheets.
Apex
Jun 19, 2013
1,229
C&C 30 Elk Rapids
run a tape meaure up the main halyard? Topping lift? Close enough should be good, as the trnbuckle can take up the remaining amount for fine tuning. Sorry no dimensions.
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
Here are the specs for the 1979 model, doesn't mention the split though. A call to D&R Marine should get an answer as to the correct length and wire sizes, Rudy Nickerson could make a replacement for you, but shipping charges might make a local rigger less $$.
O’DAY 28 RIGGING SPECS
(Taken from a 1979 O’DAY memo)
(All Lengths and specifications are approximate and are subject to change without notice)
Main Halyard (rope) 3/8” x 68’
Jib Halyard (rope) 3/8” x 74’
Mainsheet 3/8” x 45’
Jib Sheet 3/8” x 30’ (2)
Mainsail Outhaul 3/32” x 7’ wire (7 x7 SS eye to eye measurement)
¼” x 9’ Dacron
Topping Lift (rope) Mast: ¼” x 31’
Boom: ¼” x 15’
Spinnaker Halyard 3/8” x 90’
Spinnaker Pole Lift 3/8” x 48’
Spinnaker Pole Downhaul 3/8” 30’
Spinnaker Sheets 7/16” x 48’ (2)
Genoa Sheets 7/16” x 40’ (2)
All running rigging is typically double-braid Dacron (Polyester) rope
Standing Rigging Specs.
Headstay 7/32” x 37’5”
Upper Shroud 7/32” x 35’
Aft Lower Shroud 7/32” x 18’7”
Forward Lower Shroud 7/32” x 18’ 7”
Backstay 7/32” x 38’6”
All Standing rigging is SS 1x19 type wire and lengths are with turnbuckle (where applicable) closed, from eye to eye (most riggers measure with turnbuckles half-closed, so be sure to note this and/or bring old rigging to rigger to measure for replacement)
Jun 2, 2004
1,957
From a 28 Manual that I found on-line:
Backstay (overall) 37'9"
(Upper section) 31'7" 7/32" 1x19 wire #7 eye at top, jaw at bottom
(lower section) 6' 5/32" 1x19 wire #5 jaw at top, turnbuckle at bottom (I assume 2 of thse pieces needed, one per side?)
Aug 17, 2015
7
oday 28 rock hall
"Spinnaker Pole Lift 3/8” x 48’"
I have a spinnaker halyard, but I dont have a "Spinnaker pole lift" on my o'day 28. Is that three forward facing sheaves on the mast-head?
Thanks
Chris
