My O'day 31 has the traveler mounted over the coachroof as do other models. The traveler is mounted/supported at each end on pedestals. I would like to drill holes through these pedestals to lead halyards and reefing lines to the cockpit winches through stoppers.
My question is regarding the composition of the pedestals. They appear to be FRP shells, but have a solid feel and solid sound when tapped. Does anyone know what is inside? (wood block? other coring?) The screws holding the traveler track to the pedestals have a different on-center measurement than the bolts or machine screws extending through the backing plates inside the cabin. I would hate to start drilling horizontally only to run into vertical fasteners or aluminum framework.
Anyone have experience with this????
