Oday 28 1995 Universal 12 10hp diesel - starter replacement
Nov 29, 2021
28
O'Day 28 Milwaukee
Hello, I want to replace my starter. I believe my brushes are starting to go. I bought a new one recently just curious if anyone has any suggestions before I start this project? Has anyone done this before, how difficult may this be, etc?
Thanks in advance
Once you have the starter off, take it to a local auto electrical shop and have them take a look. Brushes should be easy to replace and less expensive than a new starter.
Mar 5, 2010
13
Oday 28 St. Louis
I did this last year, very easy once you take off the alt. Mine starts like a new boat now.
It is a project that you can accomplish with a little mechanical understanding of your diesel engine and some basic tools. Be sure to disconnect your batteries first. There will be a large cable going to the starter. It is safer if that one is not directly connected to the battery. Take a picture of the wiring before you disconnect any wires. There is a pretty good chance you’ll forget where they go when you get to the reinstalling wires task.
Good luck.
Catalina 34 Casco Bay
Had my starter rebuilt. Before that process I had a bitch of a time removing it. After it was removed and rebuilt I decided to replace the very rusty bolts with SS... wrong.... killed the ground plane.. so back to steal and everything was good....
