A few words about saildrives
I recently purchased a Nonsuch 30 with Volvo MD11C and Volvo saildrive. The engine and saildrive were the original 24 year-old units. The engine was raw water cooled via the pick-up on the saildrive.As luck would have it, the engine failed the survey and the owner had to re-power with new engine and saildrive in order for me to make the deal.Like many people, I was a bit uncertain about saildrives and decided to look into them a bit further. Here's the upshot of it all:Like all things mechanical, a saildrive is only as good and will last only as long as the owner maintains it. While the OMC saildrive certainly had its problems, many of them were owner exacerbated. More often than not, it was due to lack of knowledge.However, with the passing of OMC, and saildrive parts becoming more scarce and increasingly expensive, I personally would opt for a different aux. If you're the unlucky owner that this unit dies on, you're in for a major expense with regard to re-powering. My re-power cost a total of $15,650.00 for the aux, saildrive, misc parts, and labor. If I was going to have to pay for it, I'd have walked away from the deal.As it is, I am enjoying the new boat and am maintaining the aux and drive meticulously. It's the only way I can be certain of not running into problems in the future.As far as your considering the purchase of an unknown quantity, I have to agree with Marvin. Unless the owner can produce some solid documentation with regard to maintenance, I'd run like the wind.There are plenty of good boats out there and a nice diesel inboard would certainly do the trick. Consider a 272LE if you are looking to stay in that size range.At any rate, good luck in your quest.Cheers,Bob
