26 mast raising - no problem
Hi KimI appologize for the blind contact. I was reviewing the recent questions in the Oday owners chat room. I wanted to let you know that getting your mast up or down is really easy with a few tools and alittle confidence that comes from practice. I used to do this as a good samaritan around my local marina in the spring and fall for many, many boats of all makes and sizes. I even talked a couple new to sailing (that bought an Oday 240 from me and transported it down to washington DC) through the process over a cell phone.You will need some special tools to assist you. Have no fear... a lack of some tools can be compensated for by using more bodies on board to assist your undertaking. A mast crutch, two 20' to 30' lines, and a block and tackle system (3 to 1 minimum, 4 to 1 better, 6 to 1 even better.) This block and tackle should have a cam cleat system attached to one of the blocks!!! Look around your boat...The block and tackle system sounds alot like the boom vang on many boats! Every boat will have the lengths of line laying around somewhere! The crutch can be replaced by extra helpers, or someone in your marina may have a MAST UP" crutch" to loan you if you ask, or you can build one real cheaply. My system uses a (6 to 1) main sheet block with snap shackles attached to each block from a catamaran. (You can also use the boom vang from the 272LE if it’s large enough.) Some people use a 2X4 A-FRAME. I made a 2X4 vertical elevation post with a single keel roller mounted on the top. Two ten foot 2X4’s held together by aluminum straps can slide vertically and be held in place by a carriage bolt that runs through both boards in predrilled holes, and elevates from 10’ to 16 or 17'. This elevation seems to make raising the mast easier since your most of the way there to beating the leverage problem. This rig can be secured by placement into the scupper well at the rear of the cockpit and running rope from the rig to the cleats on both stern quarters and from the rig to the stern pulpit. Run this rope at two levels to keep it from kicking out while the mast is resting on the roller overhead. Attach the block with cam cleat to the bow stem fitting and the other block the bottom of the furling unit. If the rope is long enough it can be run outside the bow pulpit and back to the primary winch, if not the cams on the block are great security to allow one person to either pull the rig up or lower it down carefully. All that’s left is to set the upper part of the mast in the roller atop the 2X4 rig and push from the mast base so that the mast rolls out over the roller until the bottom of the mast is located above the mast tabernacle and push the pins into the appropriate slot to secure the mast for raising. Now pull or winch up while a 2nd person simply acts to steady the masts side to side motion. When it’s up, use the jib halyard to reattach the block system disconnected from the furler bottom. This will give you the leverage to pull the mast forward enough to set the clevis pin under the furler to the bow tack. This may be the simplified short version, but it demonstrates the major points.I can set up a boat and raise the mast in about an hour with just alittle help from a boat owner. You may take longer, but believe me it's easy and you will get faster with practice. I’m sure you know enough to have the back stay and shrouds (port and starboard) secured before attempting a mast raising. I only mention this because every year I either hear of or witness someone who forgets the basics and the inevitable accident occurs. Caution and adherence to the check list philosophy utilized by submariners and pilots is my creedos. Good luck later this spring. Call me if you have any questions. Scott SchellDavid Scott Schell724.368.3480 telephone724.316.9150 celldschell@zoominternet.net
