Oday 26 Newbie
Apr 15, 2015
61
Oday 26 Gloucester
Ok, I am a newbie sailing this year on my Oday 26. I have been learning and things are going pretty well. I do have a question.
The other day I was out and the wind was blowing 5 to 6 knots. The wind started to increase. As a newbie I just pointed a little higher and managed this little puff. Then out of nowhere there was a blast that heeled the boat way way over. A lot of items that were on the high side down below came hurling across the cabin. This was a very short event. I think the boat rounded up with my help as I was scrambling to let out the jib sheet a bit and also trying to turn into the wind with the tiller. It was a little scary. Is this common for a blast of air to come out of nowhere. 5 minuets later we were back to very light winds.
thanks for any input.
Jun 24, 2014
74
Kayaks for now, oday coming soon 13 Waterford, CT
Yes it's common enough. It's called a lifter, meaning it makes you move faster and therefore your boat points a touch higher. They can get you out of a pinch. Learn to enjoy them.
If you are sailing near land, sometime the wind isn't clean and changes direction a lot as you pass structure on land. You need to learn your local area to know what affect the wind when it's blowing from this or that direction.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Weeeeeellll... the answer is that even with steady winds, you can expect the direction to veer from time to time, often in a fairly regular pattern. From racing, we have the concept of lifts and headers (also known as "knocks.") Let's say the windward mark is at 0º and average wind is also from 0º, and you are riding the average wind close hauled on port tack at 45º. If the wind veers to West 10º, then you would have a "lift," sailing closer to the mark, and you could ride this at say 35º. This is good, giving you better course made good toward the mark. But if the wind veers East 10º, then you'd have to fall off to a course of 55º in order to keep the sails filled. This is a "header" or "knock." The rule in racing is to tack on the headers, in which case you'd be lifted on the opposite tack, and to ride the lifts, because you'd be pointed closer to your destination. This allows the boat to be pointed closest to the mark all the time. The trick is to A) know the average wind direction. B) know if the trend is towards puffs in a particular direction C) anticipating a header to be ready to tack.
There is also something known as a "velocity header." This is when you are sailing along and the wind lulls. Because your boat speed is faster than the wind speed during the lull, the sails luff as if you were just headed - but you were not. In this instance, its best to leave your sails trimmed, and ride the lull until the boat slows down and the sails draw, or the wind picks up again to drive the boat.
On my lake, when we get NW winds, say, when a high pressure system comes in after a storm and the air clears and cools, we also get a lot of lifting gusts. Much of this flukiness comes from hills along the North side of the lake, further complicating matters. Specifically, you can be sailing along Westward, nicely closehauled on a starboard tack, riding a WNW wind, and suddenly, the wind lifts to NNW with a strong gust. Being a dinghy sailor, I used to allow the boat to round up for these events. Then, as I became more confident of ballast in the stub keel, I'd allow the boat to heel and ride out the gust, often "washing the toe rail" in the process.
Except for that couple weekends in a row last Fall, including the day of tremendous gusts. I was out with my reef in, and jib up, sailing as described above. A gust came, and the boat heeled. The toe rail washed. Then, for a real good toe rail washing, water splashed on the top of the coaming because the lifeline stanchion base was in the water. Then I felt I was awfully high up on the windward side. THEN I noticed that water was pouring in over the leeward coaming. That's about when I decided it would be a really good idea to round up. After the boat leveled off, I decided it would be an extremely good idea not to do that again, 'cos that was a fair amount of water in the cockpit. I sailed along for a while further on that tack, rounding up for everything (even though I hate to slow down like that) just so that the seat could dry off for when I tacked around so I wouldn't get my butt wet :D I tacked around then fell off for a broad reach back to the marina, figuring I'd had enough fun for the day (it wasn't that much fun with all the gusting) and that I had tempted fate well enough for the day.
If I remember correctly, that was the day before the marina limit, and I had to haul out the following day. I believe I had mocked people hauling out earlier that day, by saying "I'm goin' sailing, whooo hooo!" And fate and weather slapped me with 40 knot gusts the following day when I had to haul out. To prepare for the haul out, and to deal with that crazy wind, I stripped off all sails, running rigging, and stowed the boom in the cabin. I had nothing on deck save me and my fenders and dock lines. After I got the boat out with the help of club members. I had to use the flat-bottomed club chase boat to tow 4 other boats back to the launch ramp, including a 23 footer. (Our marina is capped at 24' length, with one 25' exception.) I'm still not sure how I got that 23 footer in to the ramp dock without blowing all the heck around! :D:D:D
Oct 10, 2009
1,120
Beneteau 393 Muskegon
You'll learn they don't come out of nowhere. Watch the water to windward and you will see those gusts coming, giving you time to prepare.
Ward H
Nov 7, 2011
3,843
And always secure items in the boat. Nothing on the benches or counter because they will end up on the floor. I've learned the hard way to always prepare for the un expected.
As Indy said, learn to read the water so you can prepare for the gust. One thing is certain, it will happen again and you now know you will survive it.
Sounds like you are enjoying your 26. Very good!
Apr 15, 2015
61
Oday 26 Gloucester
Really enjoying the 26. Thanks for all the replies.
Don't think I have broke 5 knots as of yet. Close but no cigar.
