O'day 25 - Shore Power
Mar 12, 2013
28
Oday 25 Milwaukee
Hi, I'm updating the "shorepower" currently installed on my 75 O'day 25. The current setup looks like a previous owner's bad diy project. There's currently a female(!) 30amp plug installed in the side of the cockpit wired with romex (and electrical tape) to a single duplex outlet. The "shorepower" cord was a household extension cord with a 30amp adapter (and electrical tape of course). I have since purchased the correct type of locking power inlet and an actual UL listed cord. The one outlet is strictly used for low draw items like phone chargers, a small flat screen TV for the kids, etc. My question is this: What other electrical equip do I need to install (breakers, GFCI outlet, etc.)?
Thanks!
Kevin
Ward H
Nov 7, 2011
3,843
Kevin,
When I bought my 25, I thought I would need to install shore power but did not really want to add another system to my boat.
So I asked myself how much overnighting would I really be doing at the dock. Turns out not much. When I do I just run in a heavy duty extension cord.
I'm putting my money into some DC outlets for 12v appliances and adding a 2nd battery. I think I will get more out of that than an AC system.
Just because a previous only had it doesn't mean you need it.
If I did want to add shore power, I would look into one of these kits.
https://www.ezacdc.com/boat-wiring-products/marine-electrical-shore-power/
Looks like an easy way to add an AC power system to a boat.
I'll let the experts handle what components you need for your situation.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Before you proceed with this project, you need to do a helluva lot more research.
You might start with Don Casey's book "Sailboat Electrics Simplified" http://www.amazon.com/Sailboat-Electrics-Simplified-Don-Casey/dp/0070366497
You also should read MaineSail's (RC Collins) website and forum thoroughly: http://forums.oday.sailboatowners.com/forumdisplay.php?f=135
http://www.pbase.com/mainecruising/boat_projects
I know other people who feel that this is not enough, and that if you don't want to burn down your boat, you'll have a competent professional marine electrician do the work properly for you.
Jun 2, 2004
1,957
Oday Day Sailer Wareham, MA
One thing is to get rid of every inch of "romex" or other household wiring in the boat. If you choose to install a proper Marine shorepower setup, use proper marine-grade wiring, that will be multi-stranded, not solid conductor like romex. I'd follow the advice above to consult Don Casey's book, a GFCI should be in the circuit for protection and proper grounding needs to be installed.
Second option, can those small battery chargers and the flat-screen be DC powered?
Mar 12, 2013
28
Oday 25 Milwaukee
I've got Casey's "This Old Boat" and have started reading up on the subject. If the AC does not interface with DC in any way; and the AC runs to just 1 outlet; about (18" from the shorepower inlet to the duplex outlet) what if any special grounding is needed?
Thanks
Nov 9, 2012
2,500
Mar 12, 2013
28
Oday 25 Milwaukee
Thanks for the link. That's basically what I have; a shore power inlet hard wired to one GFCI duplex outlet, I would just need to add a dual leg breaker panel. No grounding or connections to the DC system.
There is another option, for super simple A/C shore power on a boat. This will provide just 2 A/C plugs: http://www.leftcoast.biz/iWeb/Left_Coast/AC_deck_plate.html
If I were going to do one of these, I would contact Left Coast, and ask if they could make it with a Smart Plug http://smartplug.com/marine_30amp.html instead of the regular horrible 1938 NEMA L5-30 plug system which has been a sub-par standard for far too long. http://www.pbase.com/mainecruising/installing_a_smart_plug
