Does anyone know of a good source for replacement hinge pins for a 1976 oday 25? Also, if anyone knows the size specs that would be helpful. Ive looked online without success. Thanks in advance!
It depends on the make of the hinge. I've seen at least one O'Day boat with two different diameter pins. If you have a Dwyer hinge tabernacle similar to the one on my boat, you could get away with two 3/8"X 5" stainless steel bolts which are threaded about 1" from the end, w/ two lock nuts. I keep two bolts in my ditty bag just in case I ever lose a Tabernacle pin. I've never had to use them, but they're there just in case.Does anyone know of a good source for replacement hinge pins for a 1976 oday 25? Also, if anyone knows the size specs that would be helpful. Ive looked online without success. Thanks in advance!
I did the same thing years ago Rich. I couldn't find my pins and I looked high and low for them. I went out and bought the bolts,--and then the pins showed up. Like a friggen dumbbell I had put the pins on the upper part of the hinge on the mast and I've never done that before. I've always put the pins on the cabin top hinge. Why I did that, I have no idea.I couldn't find my pins when I stepped my mast two years ago so I went to the hardware store and bought two stainless 3/8 bolts. Worked fine except the ends weren't tapered and it was a little harder to start them in the holes. Get the pins if you want to but use bolts if you have to. I knew I would find my pins later.
Rich
