Oday 25 cushions
Ted Kaperonis
I recently took ownershbip of an Oday 25. When the main berth base is pulled out, I do not know where the cushinns are that fill in the back rest for the matress!
May 31, 2004
858
Catalina 28 Branford
If its like the 23
If the 25's set up is like the 23 (and I think it is), there is one large separate cushion that fills in the gap created when you pull out the base of the main cabin berth. There is no clever storage space on the boat for this cushion, so if you plan on using it for a cruise, you have to find a space for it in the cabin. More often than not, mine resides on top of the berth or in the v-berth until it is needed at night. When I am only daysailing, I keep it in the basement. If you don't have one of these cushions, you will have to make one.
H
Herb
Cushion
On my 26, the cushion is stored aft of the berth on the port side next to the engine compartment, on edge like a backrest. Herb
