Adams asked?
Adams asked, "Is there an open chamber between between the fiberglass in the trunk and the fiberglass on the top of the trunk that's visable in the floor of the cabin?"
Good question. I have seen the area on the 25 and 26. My impression was that it should be solid. I have never cut into it.
Could there be a cap or liner to the bilge? I guess so. I did not think that there is enough room nor any separation. That would account for the uniformity of the bilges between boats. So, what else?
Delamination is a possibility In the north, water may have gotten in and caused a layer of delamination. Or a very severe grounding may have cracked the inner layer causing subsequent delamination.
I would find out what is going on. I suggest using a hole saw to drill an adequate hole to inspect and evaluate. Sounds like a potential epoxy repair.
Ed K
26
I have water in the the bilge area under the floor in the main cabin. With the centerboard removed I use an air compresser to blow air into the bilge through one of the screw holes and found air coming through a small crack in the side of the top of the centerboard trunk. My question is how did air get from that screw hole to the the top of the centerboard. I thought that that the fiberglass that forms the top of the centerboard trunk was solid fiberglass. Is there an open chamber between between the fiberglass in the trunk and the fiberglass on the top of the trunk that's visable in the floor of the cabin?
