I have four windows on my Oday 23 that need resealing. I took out the larger port side window and cleaned out all the ineffective window glazing that was added. Is it normal to have just two sheets of fiberglass roughly cut to accommodate the window frame, or am I missing something in between them? It seems when I tighten the screws, it will always pull on the walls unevenly, creating leaks. Should I maybe cut a donut of wood, or HDPE to put between the walls for stability? I've heard of marine silicone. Is this what should be used here? I also have butyl tape, but that seems like it would be too bulky for this application.
Also, how hard is it to polish the plexiglass? These really are showing their age.
And do you think I should I take the frame completely apart and reseal the tinted plexiglass into the frame?
