With ideas from Francis and Scott on eagles wings I went to the boat I am considering buying to evaluate what I thought was leaks at the bow pulpit backing plates and nuts. To my surprise The anchor locker drain hole on the bow near the eye had a small plug in it. In pulling the plug, there was no hose attached from the anchor locker. The water which was in the bilge and I thought came from the pulpit nuts, was draining through the anchor locker drain hose . The water went behind the hull liner and subsequently into the bilge. Good to know the problem wasn't pulpit nuts. The help I need is can some skipper tell me what small thru hull goes in the drain hole or what remedy you had for this problem. I can't imagine an owner plugging the drain hole and letting water run down the hull liner making wet liner and unhealthy condition. Any help is appreciated. Thanks Roger
