Bill Jones
I am reworking the Sink/Ice Box console of my 23' Oday (Rotted drain hoses to the thru hull fitting). (Lucky that there was no leak below water line.) (I believe the thru hull is stopped up by barnacals.) I expect no problem with replacing the drain lines, BUT I cannot trace the water input line to the faucet, from whence it comes. Also, it appears that the faucet was designed as a lever operated pump. (The lever just flops around now.) The boat has no water tank, so installing a tank is part of the task. Can someone tell me where the line to the faucet originates? It appears that I will need to cut a hole at the forward side of the sink console to route a new input water line to a deck mounted 15 gal tank to be installed forward of the Mast. I think that gravity flow will be sufficient.This is part of a larger project to convert from a Day Sailer to the amenities of a fully equipped Pocket Cruiser. Installed to date are: A 1200 wAtt AC Generator, 50 amp DC converter/charger, Garmin GPS/Depth Sounder combo, VHF, 12 and 24 Volt interior lights, 115 V Electric cooking appliances, Bimini top. Ahead to be installed is a small cabin top air conditioner, and fabrication of raised top screens. I will correspond with anyone interested. Bill Jones- Email BJBILL1317@aol.com
