I'm new to the O'Day and the use of centerboards. I'm used to retractable keels. I have a few questions about the 50 lb. centerboard that has a tendancy to get stuck..
First of all I can't understand why the design of the Oday 23 includes the UGLY post that is in the center of the cabin. Has anyone ever modified this and removed the blasted thing altogether?? I understand it being used as a table leg, but I rarly use the table. I'd like to rig a way to remove the post and pull the centerboard up by hand and cleat it. 50 lbs can't be too difficult.
Also - how important IS the centerboard?? I would assume that the keel would provide enough ballast to keep the boat stable - does the centerboard mainly help when sailing up wind in terms of speed or is it a stability factor?
If the centerboard causes as much trouble as it sounds.. would it be crazy to just not used it?? Or is this a ridiculous idea?
I'd appreciate any thoughts.. Thanks!!!
