Archives
Search the archives for more on this subject.key word: Mast stepmodel: 222Search the title and textYes, it sounds like you have some damage to the bulkhead. I suggest removing the chainplates and see what's going on. Odds are this isn't a fiberglass repair as much as wood. Sometimes the bulkheads suffer from water damage without too many outward signs. If you pull the chain plates make sure you check the wood core of the deck for water damage as well. I know the chain plates are short on this model, and one solution for greater strength is as follows: For each chain plate take a section of flat bar stainless steel the same width, thickness and twice the length, use the chain plate as a template and drill matching holes in the upper section of the bar stock, drill two more holes in the lower section, take another section of stainless and use the two lower holes as a template, cut it so that the chain plate and this section equal the long section and drill it using the lower holes of the long section as a template, I would polish the stainless stock with buffer and abrasive for a better appearance, next bed the chain plate with a thickened epoxy and through bolt it to the long section of stainless backing it on the other side of the bulkhead. Drill the two new holes and do the same using the short section of the stainless. This will increase the strength of the chain plate in relation to the bulkhead, it does not, however, make the chain plate stronger. This modification can be used only if the bulkhead is in good condition, if there is severe water damage then the bulkhead will need to be replaced. Also as a footnote if you bed with epoxy, hardware can be difficult to remove. To simplify this just heat the bolts with a soldering iron to free up the bolt from the epoxy.Whew! Sorry for the long winded reply....too much caffine.Good Luck
