O'Day 22 vs 222
Ron Tosti
Hi..looking at O'Day 22's and 222's..what is the difference between the two boats for 1984? Thanx, Ron
Brad
No '84 O-22
The Oday 22 and 222 were not made at the same time. The 22 was made up to about 82 or 83, and was replaced by the 222. Some of the differences are cosmetic - the 222 is more "modern" looking with an wedge-shaped cabin roof line. It also has a single port on either side. There are other differences, but I'm not positive what they are and don't want to mis-state the facts. Brad
Mike C
difference
the O'Day 22 is a masthead rig and the 222 is a fractional rig. The 222 points much better than the 22. It has a smaller headsail with the fractional rigging. Inside, there is no full bulkhead wall in the 222, but there is in the O'22 Earlier 22's had a fixed shoal draft keel, later models had a centerboard. The 222's have a centerboard (????)
Marylin C.
222 Versus 22
I have owned both a 1976 O'Day 22 and, now, a 1986 222. The 22 did not change much over the years and it did have a fixed keel. This is fine if you are equipped with a depth finder or you sail deep waters. The draft was a respectable 24", however, the 222 has a 22" draft. Either way not much difference. However,the 222 has a centerboard and that makes for convenient sailing no matter where you are. The 222 is ALOT more boat than the 22. It is newer and better laid out and feels like much, much more sailboat. I looked at quite a few 22 ft sailboats before my 222 purchase and this has the best possible layout in my opinion. She's stable, comfortable, spacious and a great daysailor. In addition, she's quite attractive as well. The 222 feels like a larger boat than 22 foot. I would definitely suggest the 222 before the 22 (but either one is a good choice). They only made about 600 or 700 222s and it will be a good challenge for you to find a great one. Since O'Days Rule ...you really can't lose. Good luck!
Ron
222 vs 22-Marylin
Marylin..thanx for the reply..I feel the same way about the difference and the 222 seems like a much more civilized boat..found a great 86 222 and bought it today..it is in unbelievable condition..like new..thanx for your input...Ron
