oday 22 tallmast
G
Glynn Garland
how many shrouds on each side of the mast and if so, do they attatch to the same padeye ???
Aug 1, 2005
25
Macgregor 26S KC
shroud connections
Glynn, I would think that each shroud (same side)would connect to a seperate padeye. I have never seen two shrouds connect at the same point on the deck.
H
Herb Parsons
Shrouds
I can't say 100% positive, but I believe your boat has only a single set of lowers, and a single set of uppers. Upper and lower on one side come to the same chainplate. The lower goes to a pad eye at the spreader, the upper goes to a padeye at the mast head.
Aug 2, 2005
1
- - Green lake Spicer Mn
shrouds
Hi Glynn, Yes the boat has two shrouds on each side upper and lower and yes they both connect to the same padey and also cross each other on the pad eye. For verification of this go to oday owners home page and click on resources then boat documentation and find the rigging instructions for o-day 22 and look at how they are connected on the drawing from the original manual. and all will be clear. Happy sailing !
