Oday 22 questions
Bian
I am looking at purchasing a 1985 Oday 22 and have some questions. This boat has a swing keel. Does it also have a solid keel that the swing keel swings out of? The boat is in the water in a rental fleet. It appears to be in very good shape. Is this boat easily trailered and launched from a launch ramp? How about ease of single handed sailing? Any other concerns I should have that might be particular to this ? Thanks for your help. Brian
Stu
O'day Centerboards
Hi Bian; You are looking at a O'day centerboard which has a shallow, long keel with a hollowed-out slot in the bottom of it. A 60# -or-so blade fits into the slot and is lowered by a pennant that runs from the cockpit (just at the foot of the companionway) down through the hull via a metal tube into the centerboard slot. The blade is about 4 feet and change in length and tucks up into the slot almost completely. It pivots about the front portion of the keel and at low speeds in choppy seas, it will rumble about down there. I try to avoid strain on the bearings by pulling up the blade when the seas get choppy and there's little wind (lots of powerboat wakes!) The centerboard is preferred for it's ability to point better in the boat as opposed to the shoal draft keel. The draft with the blade all the way down is somewhere around 4 feet or so. The O'day in general is very easy to sail single handed. They don't have too many sail controls and very forgiving. Does you boat have roller furling? - it's a BIG help when single handed sailing! Look to make sure the chainplates are in good shape, look to see if there's rot where they are bolted to the bulkheads. Also look for wear in the deck at the mast step. If the rigging was overtightened, the deck at the mast step can get deformed. That is also a spot where doftness inthe core material can occur from water getting into cracks in the gel-coat. Check teh condition of the centerboard pennant - it's best to replace it with a polypropelene type of line that is rot-resistant. This is best done when out of the water and on jack stands. You need to drop the blade 50% to access the line. Check the motor mount to make sure it's solid to the transom as well as the rudder gudgeons and pintels. Let me know what you see and I can add to it if need be. Good luck, Stu "Karakahl" 1979 O'day CB Centerport, NY
Bian
Thanks
Thanks Stu, I willcheck all of those things. What about trailering the boat? I have a dry storage space accross from the boat ramp here. The mast would stay up and I would launch from a very good ramp across the street. The boat is in a rental fleet so the bottom bets cleaned every month, it has a new head and main sail, roller furling and the standing rigging is checked every month for insurance reasons. I did notice that I could not pull the center board up. Should it be easy to do? I suspect there is some sea growth in the trunk that the hull cleaner can't get to. Thanks, Brian
