Hi,
I have a 79 O'Day 22 which leaks when in the water. In good drive weather low wind sailing from completely dry it has roughly 1" of water in the bilge after day sailing and at the dock. At first I though there was a leak around the swing keel line but I've sealed around there with a brush able penetrating epoxy and sealed with silicone any thing which looked likely.
The other thing of note is the water does not leak out when the boat is on the trailer making me think that either there isn't sufficient pressure or the leak is above the bilge
My next thing to look at is the sink drain (the sink wasn't used) it seems a good solid fit.
Any other ideas or direction would be greatly appreciated.
Thanks
Andy
Thanks
Andy
