O'DAY 22 ballast & weight
mactay
May 26, 2014
1
Oday 22 Clark Hill
could someone please tell me why the spec's that you have listed show that the 22 could have a lead ballast or iron. my brochure shows it's lead, is that valid.
it's a 1980 model
also could someone tell me why your listing shows two weights, 2083 & 2283?
thanks, just bought mine and looking forward to really having a good time. I may need to ask a number of questions, hope no one minds.
thanks,
mactay
Oct 19, 2009
97
oday 22 Lake New Melones
Congratulations on your purchase.
I have a blast with mine, I hope you do too!
Oday built several versions of the 22 with either a fixed shoal keel or a swing keel. I believe the swing keels were iron. They also increased the ballast over the years which is why later ones were 200 pounds heavier.
Greg
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
1973 - 1978, 600 lb lead
1979 , 700 lb
1980 - 1983, 800 lb
1984 up was the oday 222, a totally different boat.
I have seen the 73 listed at 1800 lbs and 2083. I tend to believe the 2083 wt. at least with gear.
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
O'DAY NEVER, ever, not even once, NEVER, and I mean NEVER!!!! built a single boat with a swing-keel!! They built centerboard boats, Keel/Centerboard boats, shoal keel boats, fin-keel boats, several wing-keel boats, even a few designs with dagerboards. But they NEVER built a swing-keel boat, NEVER. O'DAY made a strong point as to why their K/CB boats were better than their competitors' swing-keel designs, that was a BIG selling point in the late 1970's to early 1980's.
The 22 always had the keel molded as part of the hull and had lead ballast inside the keel, originally 600# for the shoal-keel (1'11" draft), then when they changed to a keel/CB in 1979 the ballast was upped to 700# of lead in the keel (shallower keel requred more weight for the same stability). In 1980 the rig was changed from the original short, masthead rig to the taller fractional rig and ballast was again increased to 800# of lead inside the keel. Obviously, the weight of the boat increased each time the ballast was increased (although..... O'DAY didn't always update those figures!)
The original 1971-74 O'DAY 23 did have an iron keel in which was housed a fiberglass centerboard. This keel was bolted on, not molded as part of the hull. One big improvement with the redesigned 23 introduced as a 1977 model was the keel now being molded as part of the hull and the switch to lead ballast inside that keel.
The MARINER and RHODES 19 both had the option of a cast-iron fin keel (3'3" draft) or a 165# cast iron centerboard, the CB model of the MARINER also had 200# of lead glassed into the bilge for added stability (this was a so-called "ballasted centerboard" design, not a swing-keel since the centerboard was not the only ballast and weighed less than hte inside lead ballast, a swing-keel has all or at least the greatest major part of it's ballast in the retractable keel, very little in the hull.) A swing keel usually requires a winch to raise/lower, a CB can often be raised/lowered using a simple line tended by had, no winch needed. When you retract the keel on a swing-keel boat, the center of gravity also rises since the weight of the keel is being raised up closer to the waterline level. A centerboard or keel/CB can be raised/lowered with only the minutest chnage in COG, since the CB weighs little compared to the weight of the boat. (Ballasted CB boats, like the Mariner come close to being exceptions to that rule......when the Cb is as heavy as the 165# one in the Mariner/R19, but she is still considered to be a CB boat.)
The early years for the Mariner there was a small crank device to raise/lower the CB, but she was still a centerboard boat. The 1971-74 O 23 had a crank to raise/lower the CB due to the CB being raised/lowered from the cabin, in the later years of that design, I think the crank was eliminated? and hte Cb just had a cleat on the post in the cabin. 1975 and early 1976 models of the 25 also used this crank setup, but the CB only weighed about 40-50# so was still a CB not a swing-keel, since that weight was very small compared to the 1525# of lead in the keel itself. None of these crank devices really had that much mechanical advantage as would be needed to raise a 350# to 600# swing-keel.
It is funny how O'DAY never mentions in the brochure page below that the K/CB design O'DAY's draw more water so may require more depth of water to get on/off the trailer than a swing-keel boat......... I'd still prefer the K/CB! That after owning a retractable-keel boat for 38 years, loved the way she sat low to the ground while hauled out (keel-up draft of less than 12"), loved the way she effectively became a fin-keel in hte water with the keel locked down, almost the best of both worlds! Still, I envied the shoal-draft of a K/CB boat, the lack of a keel trunk dividing the cabin, the ability to adjust the balance of the sailplan by raising/loering the CB. Finally, the nerve-racking task of raising/lowering that 360# keel in hte spring and fall..... sure was getting real old after many years. Maybe someday...... when I can afford to replace my DS II....... I'll start looking for one of those O'DAY K/CB designs!
abrown
Apr 3, 2023
4
Oday 22 Bay Pines
I know this is an old post but I have a Oday 22 with a swing keel. Year - 1984.
Arrgh
Oct 27, 2021
90
ODay 34 Bristol, RI
I think O'Day 22 was only built until 1983...you have the 222 which is different
Jun 2, 2004
1,952
Greg
O'DAY NEVER built ANY "swing-keel" boats, the 22 was built in 2 different keel designs, the 1972-78 models all had a 1'11" draft fixed, shoal-keel, the 1979-83 models all had a shallower keel (1'3" draft) with a retractable, lightly ballasted centerboard housed inside.
The 1972-79 Models all had a masthead-rig (22'9" mast length, 27' mast height above waterline). The 1980-83 Models had a taller Fractional-Rig (mast length 27'3", mast height above waterline 31')
In all models the keel was molded as part of the hull and had lead-ballast, 1972-78: 600#, 1979: 700#, and 1980-83 800# the increase in Ballast was due to the ballast not being as deep on the 1979-83 models due to their shallower draft, and the increase for 1980-83 was due to the greater sail area (and taller mast).
The later, (1984-89) 222 was a different model, but still had the K/CB design with the keel being molded as part of the hull and containing 800# lead ballast (1'8" draft CB up)
The 22 never had iron ballast, unless an owner added it to increase the internal ballast. The confusion may stem from the 1971-74 O'DAY 23 which had a cast iron fixed keel (2' Draft CB up) that had a fiberglass centerboard housed inside.
