I purchased a 1975 O'day 20 last fall. I found when taking it out for the first time that it takes on water through the hull someplace. Further investigation out of the water found that the leak is around the nylon pin that the centerboard pivots on. This is one of the older centerboard setups that does not use wedges or brackets. Just a 1 inch diameter pin that goes all the way through the keel.
Today, I removed the centerboard by driving the pin out. I first sanded the paint off both ends of the pin and then I used a piece of 1/2 inch PVC pipe and a hammer to drive the pin out. With the centerboard out I can look up into the centerboard trunk. it appears that the leak is around the pin based on the corosion (rust) stains caused by water leaking from the inside out when parked on land.
What kind of sealant should I use when I put the pin back in to stop the leak? Any other tips? I plan on painting the inside of the centerboard trunk and the centerboard while I have it removed. If I didn't plan on keeping the boat in the water all summer, the leak wouldn't be as big of an issue.
Any advice would be appreciated.
-Steve
-Steve
