Oday 20 centerboard pendant replacement
N
neal weingart
Does anyone have blueprints for the Oday 20? I'm replacing the Centerboard pendant and need to know if the 20 has a turning block. Have you replaced the pendant on a Oday 20? Like to hear your experience. Neal
25
Jun 6, 2004
4
- - lindenhurst, NY
my 75 pendent center board
had hole in trailing edge. pendent ran through . knot tied at end .through holein boardknotted
May 19, 2004
23
- - Narragansett Bay
Replaced this spring
The pendant on mine came straight out of a v-shaped notch in the back of the cb. I wound up cutting the old pendant off, drilling a hole thru the cb and installing a shackle. I spliced some 3-strand nylon line to the shackle and ran it thru to the cockpit. All runs fine now.
