oday 20 boom attachment to backstay
robert
does anyone have a picture of the boom attachment to the backstay and how to rig this, and when one is raising and lowering the mast, do you keep the port and starboard rigging attached? or do you disconnect. thanks rob
James
Check out the images on tis web site
Robert - are you asking about the mainshet attachment from the end of the boom? I am not familiar with the O'Day 20 but from the photos in the specs section it looks just like my 23. Photos at: http://www.sailboatowners.com/album/searchresults.tpl?fno=60&amodel=20&abrand=Oday&asite=ODO&start=1&bts=T&sku=303483286614550 If so check out the specs page for the 22. You can see the attachment in the window labeled #7 http://www.odayowners.com/manuals/22/22-2.gif Hope this helps James
robert
james thanks I think thats it, rob
thanks i think thats it
ob
Jun 14, 2004
64
- - Cleveland, OH
At dock?
Does it stay like this while under sail? How does the boom move if it does stay connected while under sail? This is my first season with my boat so I apologize if my rigging questions are dumb.
Dave K.
Undo it when the sail is up
The "Pigtail" is really only for use when the sail is down. To support the boom when you are underway you would need to add a topping lift (a line from the top of the mast to the end of the boom). This is most useful when are putting in a reef, it will keep the boom from dropping into the cockpit when you release the halyard. On my 192 (which has the same backstay / mainsheet arrangement as your 20) I added a fixed length topping lift which is the same length as the mast. This holds the boom about perpendicular (lower than the pigtail) when the sail is down but has adequate slack when the sail is raised. I hook the boom on the pigtail for a little more headroom when motoring distances.
