O'Day 192 Outboard Size??
Tim
I'm looking for guidance for the correct outboard HP for an O'day 192. The boat came with an old Johnson 4 HP which I'm going to replace. I'm thinking of either a 4 HP or 5 HP. What do other 192 owners think? Which small 4 stroke is best? Thanks. Tim
Dave K
Outboard for 192
I read an article by a boat surveyor who said he looks for 2 horsepower for each 1000 lbs of displacement as adequate power. My experience using a 2 hp Honda on my 192 confirms this - it's a bit small for the 192's 1400 lbs. It's fine for maneuvering and motoring home when there's no wind. It will push the boat well enough into a 15 kt headwind, but it's very slow going if there is more wind than that. On the other hand, the Honda 2 weighs only 28 lbs, is air-cooled (so it never has to be flushed) and it recently made the 30 mile trip from Long Beach to Catalina Island using just over 1 gallon of gas. That's running seven hours straight at 3/4 throttle which gave a speed between 4.5 and 5 kts. If I were buying a new motor for my 192, I think I'd look most seriously at the Tohatsu/Mercury/Nissan 3.5 hp. 4 stroke. Even with a long shaft, it's still just under 40 lbs, and the fact that the same motor is sold under so many brand names means that finding service or parts shouldn't be a problem. Most of the 4hp 4 strokes weigh between 50 and 60 lbs, and I don't think that the extra half horsepower is going to be worth the extra weight.
Tim
Outboard Recommendation
Thanks for the opinion. I used a 2 HP Honda on a Boston Whaler Harpoon 5.2 for several years - it was a great motor and wouldn't quit. Why were you motoring all the way to Catalina? No wind? Just curious.
Dave K
Lack of wind on the way over......
.....But plenty on the way back. It wasn't completely windless on the trip over but because it's such a long way it's important to keep your speed up. At two knots (about all I could make under sail alone) it would have taken fifteen hours to get there. If you'd like to see a slide show from that trip check out: http://www.howies.net/socalpotter/catalina2006/ The SoCal potter group is a lot of fun and they put up with me and the O'day since I also own a Potter 15 which, by the way, is the original use of my Honda 2.
Tim
Some Thoughts
Your trip to Catalina was very interesting. Some very good pictures. About the outboard: The old Johnson I've been using may have deteriorated to a point where I'm not actually getting rated power but sometimes it is underpowered depending on wind and currects. The Nissan/Tohatsu 5 HP actually weight slightly less (about 2 lbs. less) than the 4 HP because the 4 used an internal tank (as well as external connections). My reasoning was - youget the weight either way, why not get the extra HP also. I will also now look into the 3.5 HP at your suggestion. Tim
