Oday 192 (1986) replace teak cabin hatch rails.
Oct 3, 2019
5
Oday 192 Apple Valley
I have the new tea rails but don't see how to remove old rails. The cabin ceiling is covered with heavy cloth. Do I have to cutthat away to remove old attachment device (screws, glue, etc.)?
Jan 7, 2011
5,930
Oday 322 East Chicago, IN
You can check the old handrails and see if you can make out round bungs where the bolts may be. Look very closely for a round circle in the teak.
If you find one, try drilling the teak bung out, or drive a screw into it, and it might pop out when you hit the bolt head.
From there, if you can unscrew the screw, you may be luck, and you just back out the screws.
On my 1988 O’Day 322, the teak handrails are thru-bolted. Same teak bungs on the outside, but inside (I have a hard liner with holes in it for each bolt.
If thru-bolted, you will have to remove the liner somehow…and get a wrench on the nut.
Greg
