O'Day 19 Fiberglass repair
Sep 24, 2018
4,739
Catalina 30 MKIII Chicago
Whatever paint is on the bottom is ready to fall off. You'll need to sand it down, figure out what's underneath the white and then apply a compatible paint
The bow damage will likely require some epoxy (TotalBoat performs the same as West Systems) and some gelcoat. Don't expect an exact gelcoat match
Likes: shemandr
Jul 18, 2025
9
O’Day 19 Florence
Thank you. I will give that a shot. Not too concerned about matching the gelcoat. At what point does damage like this require new fiberglass instead of epoxy?
Whatever is on the bottom needs to come off before any one can recommend a repair.
The bow looks to be mostly gelcoat damage with a little bit of damage to the glass. The glass looks like either Chopped Strand Mat (CSM) or chopper gun. Its primary purpose is to hide print through from the underlying layers of cloth making not really a structural issue. To repair those areas, sand the gelcoat and feather out the damage by about an inch or so from the exposed glass and fill in with gelcoat paste. Over fill damage a bit. Once it is cured, scrub the area with Dawn dish detergent to remove the wax that is in the gelcoat and wipe with some denatured alcohol. Polyester resins (gelcoat is polyester) do not cure if exposed to air, wax is added to seal the gelcoat. The was floats to the surface and seals it. Now the fun begins, start sanding the patch with successively finer sand paper ending with 1000 or higher wet sand paper. Try starting with 220 or 320. Finish with a rubbing compound and wax.
Sep 24, 2018
4,739
Aren't you glad it's a 19' boat?
I took top side paint of the bottom of a 19' boat once. I used a sander and paint remover gel. It took half a summer. I'd probably let the water do it's thing for a season, spot sand and paint over it if I had to do it again.
It would appear that the bow is damaged Gelcoat. I’d guess that coming in hot to the dock was the cause. If the underlying glass is sound you could put dab of epoxy to stabilize the underlying glass mat. Then use a fairing compound to smooth and shape the surface. Follow that with some color matching gelcoat and you good to go.
The bottom could be cracked paint, gelcoat that is split, or anyone’s guess. I would grind out the cracks and expose the problem to solid surface. Then assess what to do next.
This is a good time to review Andy’s website BoatworksToday.com. He has years of experience with these types of challenges.
The folks at Total Boat have good products for these kinds of repairs.
