Oceanis 37 loose stanchion
Jan 28, 2021
5
Beneteau Oceanis 37 Lake Lanier
I've seen several posts regarding loose stanchions, but can't seem to find an answer. Beneteau tech help has been nonexistant thus far. The stanchion on my 2013 37' attaches to a post that is bolted to the deck. The problem is that I can find no way to access the nut without cutting thru the deck or cabin below deck. Seems Beneteau builds boats in sections, inner tub seated into outer tub, then deck attached to both. This bolt is thru the deck, fastened to outer tub, but the inner tub blocks access. Not a great design when things need fixing. Hoping someone knows a trick that will keep me from cutting into the boat.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
You might find the solution in the threads below.
Slider
Sep 1, 2014
93
Beneteau 37DK Alameda
You can get to the nut on the bolt that goes though the deck by taking out the panel at the back of the cabinet. I had just 2 that were loose and was able to get to them. Good Luck!
Likes: sail sfbay
Dec 14, 2016
48
Beneteau 37 Chichester
We've managed to tighten them on our Oceanis 37 by removing the cupboard backs, and/or some wriggling around behind the panels, and wishing your arms came with a second elbow.
Jan 28, 2021
5
That was awesome insight. Got to the boat yesterday, removed the panel and tightened the nut. Many thanks for your help.
