Jan.21, 2001Dear Rob,I've been off cruising in Martinique for a week or so I've been remiss in replying to posts, for which I apologize.On our boat the stanchions are held in place with bolts, not screws.I was able to tighten the stanchions on my boat by getting a wrench on the nuts that hold them in place under the toe rail. This necessitated cutting small slits in the headliner in some cases in order to access the bolts. If the stanchions are loose they should be rebedded with a good quality caulk like 101 or Pl 5300( not Pl 5200 since they may need to be replaced someday and 5200 is very difficult to remove.) Make sure to draw a bead around the bolt holes. I also like to put a dab around the bolt heads as well.Further small leaks around the stanchion bolts can be fixed with Tulley's Creeping Crack Cure. If you need new stanchion bases Schaeffer makes a good four bolt design available through most chandleries. If you would like a longer discussion on this check the archives under "stanchions". Fair Winds,Brian Pickton Aboard the legend, Rodney Bay, St. Lucia
