Oceanair blinds
Jun 14, 2007
185
Hunter 45cc Florida
Any information on how to remove the Oceanair Blinds in the main cabin ports for cleaning. It appears both top and bottom press into a track. I tried to pry it off track with a little pressure but if that is not how they attach, I do not want to break them
Feb 16, 2012
199
Hunter 45 CC Alamitos Bay, Long Beach
SA,
I have the same boat, year and model, going down this weekend, will take a look at mine.
Jeff
Feb 16, 2012
199
Slipin Away,
Om my boat (same as yours) both the top and bottom rail of the Oceanair Blinds in the main cabin, seem to be held in place by metal clips at either end, and are pressed into place. The "clips" on our boat appear to be a light weight metal. It is not a "track" but small metal clips (about 1/2 inch long) at either end of the top and bottom Blind Rail. It appears that you could take the blade of a screwdriver and open the "clip" enough to remove the track.
Hope this helps, if not let me know. Mine are in need of cleaning also, let me know how you are going to go about cleaning yours, as we need to do it also.
Jeff
SV / Sooooo Lucky
Hunter 45 CC
