Hi,
My 1989 Catalina Mk11 is fitted with a M25XP engine and Oberdorfer raw water pump (cover gasket model). Never had any issues with cooling despite our current seawater temp @29C. I want to change out my impeller and have not been able to source an OEM one here in Australia. I have however found an Ancor impeller (part# AN2052) which is dimensionally the same as the Oberdorfer #6593 except that the recess in the faces of the impeller are a smaller diameter which means the brass/bronze washers will not fit. I am wondering whether these washers are essential for the efficient operation of the pump? I have seen various parts diagrams e.g Catalina Direct and these don't even show the washers. Also curious about the circlip/snap ring. Can't see what purpose it serves as the impeller is obviously captive inside the pump body.
Does anyone have any thoughts on these issues?
Cheers
Kevin
Cheers
Kevin
