Yes... there is a later rig you describe:
George and Drew: At some point after 1973/74, O'Day went to the rig you describe. The backstay was in two parts, separated by the triangular plate. This plate carried a mainsheet block, and the sheet was rigged to that.I've seen this described as an "automatic backstay adjuster", as under increasing force, the backstay would tighten up. But I think the main reason they did this would have been to get the web of lines out of the way of the passengers and crew. I personally don't mind the lines, as I have them, on the early system, but I see the point. And the backstay system may allow closer adjustment of the boom to center... I'll have to compare with someone, sometime.As an aside, a happy coincidence happened when I bought the mast and rig for my boat. I bought my boat without a rig in Kingston, NY... and found a rig for it, four hours away in Pennsylvania. Ironically, the rig is the same type as mine... with a single-part backstay, no plate. It was lucky, as I think this rig is less common. Rich.
