O Day 28 radiator expansion tank
Aug 29, 2021
8
O Day 28 Somers Point,New Jersey
I have a 1986 O Day 28 with the M-12 universal. There is no coolant expansion tank . Is this normal or should i add one ?
That’s normal, at least in the sense that it’s how ours was from the factory. Never had a problem from it in many years.
Oday 30 Stamford CT
waterking2.....I have a 1983 O'Day 30 with a Universal Model 20 (5416) 16 hp engine and mine did not come with the overflow tank. I installed a Westerbeke kit on my engine with the tank located in the port side lazarette so I can view the level of antifreeze without having to remove the cap on the engine.
Aug 11, 2011
1,020
O'day 30 313 Georgetown MD
Also have a M20. I bought a generic water tank for $11 from Amazon
Dorman 603-001 Coolant Reservoir Bottle, White Universal Fit
(some folks like pictures :))
RoyS
Jun 3, 2012
1,742
My heat exchanger is the highest point my the coolant circuit. The filler neck on that heat exchanger is tall and provides sufficient space for expansion without requiring a separate expansion tank. Not all marine engines require an expansion tank.
Aug 17, 2010
376
Oday 35 Barrington / Warwick RI
In order to properly use an expansion tank, you need a bi-directional, cap for the coolant reservoir / exhaust manifold. The bi-directional cap allows for coolant to be pulled back into the cooling circuit as the engine cools.
  • Helpful
Likes: Ward H
Aug 11, 2011
1,020
@ eherlihy. Are you referring that the unit I have is an incorrect unit? I'm not following, obviously.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
The bi-directional (two-way) cap is the "radiator" cap for the coolant fill on the exhaust manifold. Not the one on the expansion/recovery tank.
Likes: eherlihy
