Can anyone recommend a sealent for sealing the installation of an O/B bracket? I have an inboard that will not start so I'm hanging a kicker. This may not be permanent so can I still use 4200 or 5200? any help appreciated.
It doesn't take much to seal these up. Just drill your bolt holes nice and snug. I used silicone on mine, as some day it may need to come off. A ring of silicone on the outside and a ring of silicone on the inside under a washer. Tighten firmly. The bolts are a pretty good way up from the water line, and would probably not leak with out anything on them at all.
