nylon stuffing box repack
224
Beneteau 35s5 bristol ri
does anyone have a good way to remove the nylon washers from inside the box to get at the packing? any photos?
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
While out of the water, I loosened the Hose clamp over the hose end that is over the main body of the stuffing box. The I slid the whole stuffing box forward, removed the packing nut and moved that forward. Then I slid the main body aft. That left the washer and some packing out of the opening of the main body. I refitted the main body into the hose and re-tightened the hose clamp. Then I just removed the packing, wiped out the inside of the main body with a dowel and cloth, and proceeded to repack. I tighten down on the packing nut hand tight and then about a half turn with the packing wrench. Then wire the nut to the main body so it won't back out from shaft rotation & vibration.
For packing I use 2 rings of Teflon impregnated Flax for the 1st and 3rd ring and put in thee Green Teflon putty as the middle ring. This provides a driples packing with no heating on the shaft.
Jan 21, 2009
260
Catalina 30 Lake Perry, KS
To make it easier in the future, I cut the nylon washers at a 45 degree angle and removed it from the shaft. Keeps them out of the way and easier to replace. Easier to remove next time. I eventually just replaced the nylon with a bronze one.
