Now is the time for the TODO list.
If you live in a warm climate like Souther California where you can sail year round it is hard to pick a down time for yearly maintance.
I picked the time from Jan. 1 untill Easter to do the things like--
Empty the boat and remove that extra stuff that just gets left in there and clean the bilges and repack the spares.
Wash the sheets and haylards and check the sheves.
Check the anchor gear.
Polish the stainless.
Wax the boat and truck.
Repack the wheel bearings on truck and trailer and check the brakes and tires.
Tune the outboard--new plugs, impeller, fuel lines, filter and line from tank to engine. Change lower end lube. Might start replacing the fuel pump diapham on a regular basis. Replace spares.
Things to build might include a toe rail, I really hate going on deck with out one. A pressure switch to alert me if the water pump fails, I always feel guilty when I have been motoring for hours and remember I haven't checked the flow.
Repaint the mast and maybe the boom this year.
What do you do??
What do you do??
