Now I`ve gone Solar...Almost
1,100
Precision 23 Perry Hall,Baltimore County
Omong the other treasures discovered in our (new) boat is an intact solar panel.
It is 12" square with some lead wire and 2 alligatr clips attached.Today at work I hooked up to the mechanic`s meter in the bright sun, reading 19 to 22 volts depending on how I face the sun. We are unable to read watts or amps with this meter.
It is ICP solution Model # SE -400 according to the sticker. I`ll be researching this more tonight at home. Wondering if this will recharge the WM Gel 86 Amp hr battery if the battery is saveable. I assume I will need some kind of regulator between panel and battery,right?
Feb 20, 2011
8,062
Boy, are you about to be inundated with information!
The panel appears to be a little small for anything other than a maintenance charge, depending on your demand.
A PWM controller can be had quite cheaply.
Aug 13, 2012
533
Catalina 270 Ottawa
guessing by the size, the panel is about 5W (i.e. it would provide about 0.4A current at 12V (not counting any losses)) . I would strongly suggest a controller (though, with such a small panel, it might not be required).
Marek
Jul 13, 2010
1,100
Thanks..gonna research batteries too, found out today mine is toast. You never run out of things to deal with, all part of the fun! Dave
Yes you will need a controller. Go to eBay or Amazon. You can get one for $20 or less. They might even have them here on this site.
May 9, 2013
6
Hunter 32 Miami
A solar panel that small would only replace power for something VERY tiny, like occasional radio use -- not for lights or electric motors of any kind.
Dec 11, 2008
1,338
catalina C27 stillwater
What is your routine use of the boat that you intend to use the charger on? I have owned several of the ICP products over the years. If you sail mostly just on weekends, without extensive electronics, lighting or other loads, even that little 5 watt panel will top a battery back off over the course of a week after a weekend if your only draw is a radio/CD player. Heck, in full sun it will pretty much run that radio/CD player! It will not do much more than that though.....
I have used that panel without a charge controller, but solar is so cheap right now, there is no reason not to go find a controller to use with it.
Jul 13, 2010
1,100
Phil (and all) we anticipate light use(HA-HA,get it..) . Our pattern last 3 years is dailsailing,only done 2 nights overnight total. We might need running,steaming lights one night on a weekend or weekday dinner cruise. Current VHF is handheld, AM/FM is a small boombox. On the P18 we made do with a riding mower battery, trickle charged it 3-4 times last summer. I don`t have a problem leaving the small trickle charger on during the week ,we are drysailing both boats. I think I will get a controller though,will experiment with this. I did find out last nght that the gel battery in the boat is toast, will be looking at various deep cycle ones.
