Nova kool freezer replacement
bart
Nov 5, 2012
28
hunter 41 cranston,RI
Has anyone found a better replacement for the Nova Kool f1900 freezer?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Replacing due to end of life or poor reliability? Consider replacing in-kind (1.9 cf) or another one that will fit the cut out dimensions of 20.625" H x 15.625" W x 17.75" D and running amps of 4.4 amps.
A replacement in-kind costs ~$1065 (from Sure Marine). A 1.7 cf Norcold costs ~$1000 and fits your dimensions. Other manufacturers like Dometic (have one on my rv), Isotherm, Raritan and U-line (had one on my power boat) will likely have one that will fit your dimensions.
Apr 5, 2009
3,211
All of the 12v conversions use the same basic parts and will a torch, sliver solder and basic fittings you can replace only the parts that failed. I got an AB cold machine and it has Isotherm evaporator and an electronic thermostat I got from Amazon for $18. I bought an HVAC vacuum pump at Harbor Freight for $100 but you can also rent them from many auto-parts stores. You do not need gauges to charge the system. Just slowly add gas until the evaporator frosts 3/4 down to the bottom.
Likes: sail sfbay
I bought one of the NovaKool freezers during the Seattle Boat Show.
Installed nicely.
I set it and the unit maintain 36 degrees. Very stingy on battery. Silent in operation. Auto switch AC/DC.
Nova Kool F3800 3.5 CU FT AC/DC Single Door Freezer
Price : $1,792.18
Our Price : $1,254.53
Jan 5, 2018
187
Hunter H34 0828 New Orleans
Yes. I’ve had it in operation since mid June. Running smoothly cool.
